Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Upholstery adhesive?
Old 02-22-2012, 08:04 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
If you're serious about doing a professional job, you need to buy a spray gun and use top and trim contact adhesive. There is no aerosol out there that is a substitute for spraying from a gun. There are products out there that you are missing. One is foam to foam contact adhesive like K-Grip or K-Spray. That is used to glue fabric, vinyl, leather, and Ultraleather to foam, or to glue two pieces of foam together. The other thing is bulk (in containers of a gallon or larger) spray grade HHR Top and Trim contact adhesive. This will glue everything you need to do on a car interior. Here's a link to a WIKI article about contact adhesive: CLICK HERE
