Upholstery panel clip for small hole? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2013, 08:18 AM
The Auveco catalog's pretty daunting, so I'm hoping for a short cut and some help. I'm using 3mm Sintra board for a backing and need clips to mount it-but in several places, the width of the metal it will mount to is pretty narrow-no room for a 1/2" hole for the "Christmas trees". Are their similar clips that would work but in a 1/4" or possibly 5/16" hole"? Thanks
Old 05-01-2013, 09:25 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Au-Ve-Co 10780 or 12134 both go in a 1/4" to 5/16" hole in the door itself. The hole in the panel for the clip is 7/16" to 1/2". I used to use the 10780 all the time, but I like the 12134 a lot better now.
Old 05-01-2013, 03:03 PM
Thanks,Dan. That makes more sense.
1936 Panel truck that needs upholstery iceman36 General Rodding Tech 5 04-06-2012 05:37 AM
stripped hole by steam hole one 400sbc projectman69 Engine 11 11-06-2011 08:30 AM
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 06:54 AM
Need some upholstery clip help/advice Irelands child Interior 35 12-27-2009 08:21 PM
Small Block Chevy starter bolt hole Rad Ray Engine 4 03-10-2003 07:14 PM
