upper a arm rubbing
I have a mustang II suspension (old style not tubluar) and when I turn my wheel all the way to the right or the left it hits the a arm. I can't use spacers because the wheels wouldn't be under the fenders when lowered (air bag suspension).
Hopefully I won't turn the car that sharp to hit the a arm but can anyone suggest something say a rubber piece attatched to the a arm to protect the wheel incase it hits. What if I rhino lined the a arm would that stuff stay on and cushion the wheel |
Limit stops
There are supposed to be limit stops on the a frame that limit the amount you can turn the wheels so this does not happen..Tho with larger tires or modified suspension sometimes they need to be extended or added to to prevent this sort of thing..
I think if you look you will see the the tire hit the frame or a arm before the spindle hits the limit stops.. If you look at a factory car you will see the spindles hit the stops to giv eyou an idea of what is needed.. Tha tis what I would look at.. OMT
Ok I will check that out. Where are the stops that the spindle hits? Are the stops part of the lower A arm?
Generally
You will find them on the lower A-arm..usually about Where the steering arm is located..that is generally..these things have been known to make me a fool at times..<<GrINNN>>
OMT
It has a manual rack and that's not hooked up yet so with that bolted up it shouldn't be a problem.
