Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Upper Ball Joint Trouble
Old 05-15-2010, 05:11 AM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
You probably need to compress the spring a bit........Where is your jack stand sitting to support the lower "A" arm?......The further out toward the wheel it sits, the more it will compress the spring (leverage)......You may be able to pull the upper "A" frame down enough with a bar while someone else threads the nut on.
