Upper Ball Joint Trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2010, 01:02 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
Hello, I replaced my upper control arm shaft and bushings on my '69 C10 and new upper ball joint and new rubber bumper. The trouble is I can't get the new upper ball joint in the spindle enough to start my nut. I have tried a C-clamp and hammer and I can get it almost enough to feel a thread but I can't get it to go any further to get the nut on to tighten it up. I checked the ball joint to the old one and it's the same. Anyone got a trick to getting it in enough to get my nut on? Thank you
Old 05-15-2010, 05:11 AM
poncho62's Avatar
Wiki Edits: 5
You probably need to compress the spring a bit........Where is your jack stand sitting to support the lower "A" arm?......The further out toward the wheel it sits, the more it will compress the spring (leverage)......You may be able to pull the upper "A" frame down enough with a bar while someone else threads the nut on.
Old 05-15-2010, 05:14 AM
You sure it's exactly the same? I did my ball joints/bushings on my '71 C20, then helped a friend do his '72 C10...and noticed the half-ton (C10) ball joints were smaller in diameter. They look identical as far as the taper of the joint, but the diameter was definitely smaller.
Other than that, another problem could be you can't get the spindle up high enough. Usually it's a problem if there's no engine/trans in the truck (not enough weight to compress the spring with a jack under the lower A-arm). If you have a spring compressor still on the spring, you should be able to get the ball joint in.
Old 05-15-2010, 10:05 AM
Drag Racing Lover
help
Thanks, keep the help coming. I'm going out to the garage and check and try a few thing that have been suggested.
PLEASE HELP! Need help to ID lower ball joint. acr Suspension - Brakes - Steering 5 11-28-2007 08:44 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 01:24 AM
Another Mustang II Question hiimed Suspension - Brakes - Steering 7 06-30-2003 09:48 AM
Mustang II upper A-arm help Pilot34Coupe Suspension - Brakes - Steering 4 03-14-2003 04:12 PM
79 Suburban Ball Joint change Help!!! mr_chickenhead Suspension - Brakes - Steering 2 01-09-2003 08:08 PM
