upper control arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2009, 07:05 AM
runn141's Avatar
upper control arm
would there be any benefit using this upper control arm on a street driven vehicle? is this the one that will allow the use of taller spindles without excessive shimming? this is gonna be on an s10
http://www.daymotorsports.com/produc...ER-CONTROL-ARM
Old 09-12-2009, 08:18 PM
ericnova72's Avatar
More for Less Racer
It is lighter, stronger, and already has a new shaft and bushings in it. It is up to you whether you need it or not. It is a nice addition, I've used them on street 70-81 Camaros before. Along with polyurethane everywhere else in the front end, car was a pretty good cornering machine, but how much of that was the upper arm I couldn't even guess. We made the decision "because they are new, ready to install, and look trick"
B-body spindles for 70-72 A-body? Crow44 Suspension - Brakes - Steering 11 11-07-2007 07:52 AM
1958 Chevy-Upper Control Arm Cross Shaft-HELP!! snowjoe Suspension - Brakes - Steering 2 05-26-2006 02:28 PM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
camaro control arm iluvdrt Suspension - Brakes - Steering 2 09-04-2003 05:26 PM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
