Upper Control Arm Axle Bushings Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2005, 07:26 PM
Steve karch's Avatar
I want to install no hop bars (Edelbrock) on my Beaumont but I am not quite sure how to get the old bushings for the upper control arms out of the axle housing. I would sure appreciate any advice on how to get them out. I've already installed tubular upper control arms (Jegs)and boxed lowers (Chassis Engineering) and air bags but still have bad axle hop.
Thanks
Steve
Old 09-01-2005, 08:42 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
A great big Hammer, LOL. I think OTC makes a special tool to push those out with.
Old 09-05-2005, 07:04 AM
Ricky Rocket's Avatar
Drive it like a rental!
Bushings
These bushings are difficult to remove and install. There are special tools to use along with a hydraulic press. If you check with your local machine shop they might be able to help you or let you know who could. I just had some replaced on upper and lower control arms for a Dodge pickup and it cost $50 in labor and was done in an hour. Much cheaper and safer that doing it myself!
Rick
Old 09-05-2005, 10:39 AM
After asking around and checking these bushings I think your advice is correct. It's going to the shop this one,
Steve
upper control arm axle bushings, remove/install ss396si Transmission - Rearend 1 02-16-2005 05:57 PM
rear upper control arm bushing removal 68chevelle_ss Transmission - Rearend 18 02-06-2005 02:51 AM
upper control arm 67 C10 wickedwitchinak Suspension - Brakes - Steering 1 12-20-2004 09:47 PM
Mustang II upper A arm removal RodFather Suspension - Brakes - Steering 4 08-30-2004 01:52 PM
Upper Control Arm Removal Question HeftyP Suspension - Brakes - Steering 2 07-15-2004 06:46 AM
