upper control arm issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2010, 07:16 PM
i just replaced the front suspension on my 72 chevelle.the problem i have is the upper control arms are sitting on the frame when the car is on the ground.the uca are still not tightened up yet.what could be the prob?appreciate any help
Old 11-01-2010, 08:26 PM
Is your engine and front sheet metal on the car? If there is no weight on the front they will hit the corner of the frame as I remember.
Old 11-01-2010, 09:42 PM
302 Z28's Avatar
As Brian has pointed out if there is no weight on the front end it's normal.
Vince
Old 11-02-2010, 11:07 AM
Also be aware that you should not tighten either the upper or lower control arm bushing bolts/nuts until the suspension is at final ride height with the full weight on it.
Old 11-02-2010, 02:59 PM
the car is with engine and body,could i have put the coil springs in upside down?ordoes it make a difference?
Spindle knuckle scrapes control arm camaroadam73 Suspension - Brakes - Steering 2 08-26-2010 06:58 AM
Removing upper control arm on a 1967 el camino 64kustomkaddy Suspension - Brakes - Steering 6 07-01-2010 02:15 PM
upper control arm bushing helrazr3 Suspension - Brakes - Steering 9 05-23-2007 09:58 PM
Upper Control Arm Axle Bushings Removal Steve karch Suspension - Brakes - Steering 3 09-05-2005 10:39 AM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
