Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - upper radiator hose
Old 11-22-2011, 07:26 AM
cliff tate cliff tate is offline
top hose colapsing
Originally Posted by Camaro820
When I tried to get the air out, after it got to operating temp coolant would come out in waves. But there is no bleeder either.
sounds like rad plugged ,causing the water pump to cavitate,this would aerate coolant and poss.reason for air in the system.also check rad cap as there is a vacuum relief which should stop the hose co lapsing.with a clean rad and system bled top hose wont collapse
