Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - upper rear shock mount bar question
Old 11-15-2012, 04:28 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
If your top shock mount is a single pin I'd weld in a boxed plate with a hole on the top tab. If it's a crossbolt, I;d weld a pair of tabs to the tubular crossmember, and drill for a crossbolt. I wouldn't bolt through the tubing, or drill the tubing, as it will weaken the tube.
The Following User Says Thank You to 1971BB427 For This Useful Post:
andrewakessler (11-17-2012)
