upper rear shock mount bar question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2012, 10:24 AM
andrewakessler's Avatar
Hello,
I'm in the process of installing a triangulated 4 link on my 48 Chevy. For the upper rear shock mount bar I was hoping to repurpose either a solid steel bar that came off my truck (pic attached), or an old barbell I had in my basement.
I'm not really sure what it's old purpose was as it was not connected to anything on the frame.
Does anyone with more experience see any issues with using either of these items?
Thanks,
-A
Old 11-08-2012, 12:16 PM
Last journal entry: was hoping for better than this
looks like it's a sway bar..
Old 11-09-2012, 08:19 AM
S10xGN's Avatar
Gotta love a turbo!
Just keep in mind, if you use coilover shocks the entire (rear) weight of the car is handled by whatever you use for the mount bar.
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
andrewakessler (11-13-2012)
Old 11-09-2012, 08:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd use a piece of rectangular mild steel tubing instead of trying to use a sway bar. Couldn't cost $20 for what you need. If you decide to weld on the sway bar be sure the welds are done right. At least for use as a sway bar the welds are critical, and to be avoided if at all possible. Might not be such an issue using a sway bar as a cross member, but still... just saying.
I wouldn't use round stock unless the quality is known.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 11-15-2012, 01:41 PM
cobalt327, If I were to use a piece of rectangular stock would you weld shock tabs onto it or drill holes through the bar?
Thanks.
Old 11-15-2012, 03:28 PM
1971BB427's Avatar
If your top shock mount is a single pin I'd weld in a boxed plate with a hole on the top tab. If it's a crossbolt, I;d weld a pair of tabs to the tubular crossmember, and drill for a crossbolt. I wouldn't bolt through the tubing, or drill the tubing, as it will weaken the tube.
The Following User Says Thank You to 1971BB427 For This Useful Post:
andrewakessler (11-17-2012)
Old 11-15-2012, 08:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks.
Unless you were going way overkill on the size/wall thickness I'd weld.
How to position rear upper coil-over mount/crossmember? jamieson Hotrodding Basics 1 05-15-2012 01:54 AM
upper shock mount relocation dboyett81 Suspension - Brakes - Steering 0 04-12-2011 09:23 PM
59 chevy apache front upper shock mount sport41 Introduce Yourself 1 04-17-2010 04:52 PM
59 chevy apache front upper shock mount sport41 Suspension - Brakes - Steering 1 04-17-2010 04:51 PM
'93 C1500 Rear Shock Mount WildBill Suspension - Brakes - Steering 1 09-03-2009 07:13 PM
