urethane dangers
I have read and read about the dangers of using urethane paints, such as the hot rod flatz. I was curious is the urethane primers just as bad? I have decided against the hot rod line due to the hazards and will just be using an enamel with a flat clearcoat instead, however i have already purchased omni 282 and the tech at the store said it was urethane, is it as bad as the paints?
