urethane flow enhancer
I have a base coat/clearcoat from house of kolor.What does the urethane flow enhancer do?Does it make it easier to spray or shine better or what? thanks proge
an enhancer lets your clear flow longer by staying wet longer. its also is easier to run. it will lay flatter and appear to shine more. but if you plan on wet sanding and buffing you'll get the same effect.house of color flows pretty good on its own in moderate temperature so i don't use it. also (h o K) is very flexible with the way they mix clear u can add up to an ounce of extra hardener to 1 quart of mixed clear and the same with reducer. i would suggest asking your local supplier for a tech book and follow it.
good luck email me with any questions @ ipaintem@yahoo.com i work in a auto body shop as a painter, ill do my best to answer you back |
| Urethane Primer | cu42 | Body - Exterior | 4 | 07-18-2007 08:31 PM |
| Urethane 2x primer on bare metal | Abby.Normal | Body - Exterior | 24 | 07-08-2007 07:23 PM |
| Which waterpump? | Eagle1 | Engine | 5 | 08-06-2004 06:38 PM |
| this is odd | astrops | Engine | 39 | 05-17-2004 07:08 PM |
| Urethane Bushings - Yes or No?? | Jim Weeks | Suspension - Brakes - Steering | 5 | 05-01-2002 08:12 AM |
