Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - urethane and polyurethane
Old 07-05-2005, 11:15 PM
kenseth17 kenseth17 is offline
Hey tish, you may want to start a new topic instead of jumping in on this one and you will get better replys. I don't know what prices are like where you are, but the prices you quoted to spend on materials won't get you far around here. I would stay away from the guy telling you the paint will peel in a few years anyways. Good paint does not peel, and if it does it is usually do to the prep and sanding, or not using the product properly. So far I would say go with the base clear paint job. Anything else I will wait till a new post. But even one of the cheapest automotive paints, acrylic enamel without a clearcoat on top should be able to last 3-5 years with good gloss, but a hardener should be used.
