If you already have epoxy primer on it, I would sand that and apply the filler on that. I believe the epoxy will give a stronger bond than the 2K urethane. If you are planning on applying that urethane on bare metal, then you want to check and make sure it is designed for "direct to metal" applications. Why don't you just go someplace else and get epoxy? Urethane and epoxy are not generally interchangeable.
Aaron |
It's not a good idea to do filler work over urethane surfacer, at the most a skim coat of polyester glaze is acceptable if the surfacer is sanded. The bond is not the same as on epoxy and you'll possibly see some mapping at some time down the road. Buy some quality epoxy or do the filler work over bare metal.
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 127 | 08-26-2012 03:07 AM |
| Epoxy vs Urethane Primer | UKLuge66 | Body - Exterior | 41 | 11-23-2008 05:50 PM |
| Question on primer for a urethane body kit | hotrodf1 | Body - Exterior | 2 | 04-17-2007 07:57 AM |
| Urethane primer and body filler | Lator_Gator | Body - Exterior | 23 | 01-08-2007 02:15 PM |
