urethane primer
what do you guys think of urethane primer, i'm working on a car for my brother inlaw and he wants to use urethane instead of epoxy. He said the local paint shop recommend the urethane because it's cheaper and would give the same results. It is a direct to metal primer and high build but i don't want to spray something that isn't going to work long term. Give me your thoughts please
Epoxy is best for bare metal and is low build so it's usually not used
when only leveling is needed, that's what urethane is for, but urethanes aren't as good for bare metal so most painters use both. Epoxy for any bare metal or sealing and urethanes for body work and light filling like scratches. They are two different products for two different applications. The "combo" ones I've tried, the urethanes rated for direct metal, had a lot of shrinkage problems for me. So I went back to useing both. That's the best way.
| Help with Urethane primer | ShamburgOffRoad | Body - Exterior | 12 | 11-11-2012 05:49 PM |
| Epoxy Primer, Urethane Primer Compatibility | brimcp99 | Body - Exterior | 7 | 11-22-2010 07:04 PM |
| Epoxy Primer & 2K Urethane Primer | acquadigio79 | Body - Exterior | 17 | 08-15-2009 04:07 PM |
| Urethane Primer | cu42 | Body - Exterior | 4 | 07-18-2007 08:31 PM |
| urethane primer | vintage guy | Body - Exterior | 5 | 03-25-2007 06:36 PM |
