Urethane primer and body filler - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-22-2006, 05:29 PM
Bodywork
Brian,
Thanks for the response. There are about two dozen little dings on the backside of the cab, most of which are about dime size and once hammered out will require half a thimble full of filler, if that.
My expectations are a pretty nice, not perfect, finish. I'm not out to win awards or even show the truck for that matter. I do have a little bit of money in it now and want it to be a nice occasional driver. It will be a stock restoration, no hot rod.
I plan on applying a single stage color coat when I get to that point.
My concern, now, is the etching primer and what Baddbob said about possibly running into problems with it reacting with the filler and/or particular epoxies. That is why I was suggesting spraying the epoxy so I could use the filler without any problems. The epoxy that has been sprayed on the doors, bed sides and hood is Dupont brand and it says it is self etching. Perhaps it won't have an adverse reaction to the Nason product.
I would love to "work with what I have" but I'm concerned about applying the filler, as explained above.
Any tips are most welcome.
'gator
  #17 (permalink)
Old 12-22-2006, 05:53 PM
adtkart@aol.com
I will say that no collision shops in my area, that I know of, put epoxy primer on the bare metal before applying the filler. That is basically because of the cost and time constraints. None of the shops that I have worked in would accept someone applying filler over primer, or any painted surface, except a product like metal glaze, or icing, where the manufacturer approves of it. Everything else is applied over bare metal.
Any work I do at home is epoxied and then filler. The quality of the repair is more important to me than the time and effort.
Aaron
  #18 (permalink)
Old 12-23-2006, 09:00 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
If the bodywork is going to be confined to small spots as you say, you would do best to feather back the primer in those areas and and apply the filler to bare metal. Repairs done this way can be quite durable as long as there is no path for moisture to enter between the filler and metal, i.e. don't put bondo over holes or seams, etc.
Of course, the very best way is with epoxy first, as described so many times already, but to listen to some of these guys you'd swear the stuff would fall off in a month if you didn't do it their way, and that's just not so. I have a vehicle that was repaired in the conventional fashion with filler on bare metal, and the bodywork is still holding up 20 years later, though I'll admit the car has not lived in a harsh environment.
  #19 (permalink)
Old 12-23-2006, 09:49 AM
adtkart@aol.com
Crash... you pretty much hit it on the head. There is what many consider the BEST WAY, and the other way. Both will work. I just don't believe in applying filler over any paint except epoxy. I have tested the application over epoxy, and know it will stay there.
Aaron
  #20 (permalink)
Old 12-23-2006, 10:01 AM
I agree, if you don't want to sand the etch and urethane off completely then take the repair areas down to bare metal, do your bump and filler work in those areas and block the rest then finish with either epoxy as a sealer coat then urethane surfacer or self etch on any bare metal spots then urethane surfacer.
But if you want the best repairs sand all the self etch off and start over with a good epoxy primer as your base.
Filler over bare metal is the standard proceedure in 99% of the shop's across the USA because of cost and time like Brian mentioned, and no the filler won't fail if done properly. But since the late 80's I've seen enough advantages using epoxy under filler to warrant using that proceedure on 90% of the work I do. It's a hard proceedure to accept for those that have done it the traditional way-it was for me anyway.... the benifits needed to be proven for me to warrant the extra cost and work. We've hashed this out on previous threads.
Blocking what you have and sealing with epoxy primer then doing your filler work is doable but the advantages are less IMO with the self etch and urethane being under the epoxy.
Reality, in the time this thread has been going a lot of work could have been done.
  #21 (permalink)
Old 12-23-2006, 12:05 PM
Thanks to all for your info. I beleive I know what to do now and we can end this thread. I've searched this site and found an abundance of good info. Thank you.
As Baddbob said, "...take the repair areas down to bare metal, do your bump and filler work in those areas and block the rest then finish with either epoxy as a sealer coat then urethane surfacer or self etch on any bare metal spots then urethane surfacer."
Merry Christmas
'gator
  #22 (permalink)
Old 12-23-2006, 02:03 PM
Hes talking dime sized dents.Whats wrong with scuffin up the urethane primer with some 120 and wiping them with polyester glaze?
  #23 (permalink)
Old 12-23-2006, 02:29 PM
Nothing at all.
  #24 (permalink)
Old 01-08-2007, 02:15 PM
BIGSKY's Avatar
See project in Photo Album
Originally Posted by baddbob
...snip...
Sorry to dig up this thread, but I just could not pass up this statement...
Its like saying, "quit arguing, get off the internet, and go sand or paint or something!" Funny stuff.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 05:11 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Body filler over the primer? Skipr Body - Exterior 3 11-22-2005 05:19 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
