Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Urethane primer and body filler
Old 12-20-2006, 10:23 PM
colormecrazy's Avatar
colormecrazy colormecrazy is offline
Paintshop Dog
If you don't need to apply filler to anything but the back of the cab, I would be agreeable with only stripping the back of the cab doing the necessary filler work. Then use 120 to block-sand the entire exterior. Then seal the whole mess with some epoxy primer and some more urethane 2K primer wet-sand and shoot. If you are confident in your existing primer it should be an OK substrate for the build of epoxy and more primer, but as stated not really the necessary foundation for filler. As for the interior the existing will probably be OK, because it will not receive the abuse of the exterior.
