Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Urethane primer and body filler
Old 12-21-2006, 02:26 PM
baddbob baddbob is offline
Originally Posted by Lator_Gator
Okay, let's assume that the etch and urethane primer was layed on properly. Can I apply epoxy over that allowing me to use the filler on top?
BTW, it is Nason Urethane primer.
Yeah, you can. The only drawback is during the sanding process you'll likely cut through the primer and if the etch primer is exposed there's no putting more filler on that area. Etch primer is forever soluable and fillers shouldn't come in contact with it. Some epoxies aren't compatible with self etch primers.
