Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Urethane primer and body filler
Old 12-21-2006, 09:22 PM
Lator_Gator Lator_Gator is offline
You mentioned the etch primer being forever soluable so I'm wondering how I strip that off with no residual effects if I were to strip the back of the cab?
Perhaps I should just scuff the whole exterior and shoot epoxy over it all, then do the filler. I'm only looking at minor dents that should hammer & dolly out pretty well.
Here is what I'm thinking of as a plan of attack. Please correct me where I've gone wrong:
1. Hammer & dolly out the dents/dings as best I can. (Touch up chipped urethane primer with same primer.)
2. Scuff the exterior with 120 grit.
3. Spray on the epoxy primer. (How many coats?)
4. Apply filler where necessary. (How long do I wait after applying epoxy? Scuff epoxy first?)
5. After sanding down the filler (what grit for final work?), apply a filler primer(a couple coats?).
6. Block sand everything.(What grit?)
7. Touch up as necessary.(Respray everything?)
8. Apply final primer.
9. Apply sealer.
10. Ready for color.
Thanks again to all for your willingness to help. I'm sure alot of you can do this kind of stuff in your sleep. For those of us that can't this info. is invaluable.
