Urgent drum identification help needed-Ford 9" diff! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 12:10 PM
turbovanman's Avatar
Working on an old Hotrod with a 9" Ford diff, I CAN NOT find drums for it, I've got the poor parts guy beating his head against a wall, must have sent me a dozen drums-they are either the wrong size bolt pattern or the drum is too small, or not as wide as this one.
Its 11" drum, 2.5" shoes, double scalloped and aprox 4.5" tall, numbers on the drum are "MW 37456R D60A 1126 A"
I googled the part number and got nothing.
Its a 28 spline axle, 5x41/2 bolt pattern, 2 3/4 centering hole, uses a sealed axle bearing, #RW207CCRA
I want this damn thing off my hoist, took me 3 days to find an axle, sign.
I found a drum that fits but larger bolt pattern, if I can't find anything in a few hours, going to redrill the bolt pattern.
Thanks.
Simon
Old 09-20-2012, 12:28 PM
Look it up for an early 80 f100 they had 5 on 4.5 bolt pattern
Old 09-20-2012, 12:37 PM
We just tried that, 11" has the large bolt pattern.
Old 09-20-2012, 01:15 PM
Thanks, looks close, I guess the double scallop doesn't matter?
The listing says 2 1/4 shoe, mine are 2 1/2"?
Old 09-20-2012, 01:17 PM
Would that work if it does ford rangers bring that drum
I hit reply to late
Old 09-20-2012, 01:18 PM
I hit reply to late
Old 09-20-2012, 01:25 PM
I was going to reply if it would work but you had replied before i did. N e way i think you are going to have redrill 5x5.5 to 5x4.5 if you want it fast
Old 09-20-2012, 01:48 PM
Technical Help with Ford/Edsel 9" differential [Archive] - THE H.A.M.B.
I found this on a google search looks
Old 09-20-2012, 03:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you get lucky the tag will still be on the 3rd member and from that we might be able to tell just where the rear came from and from there get the correct drums..But then who knows what has happened in the past..
Sam
Old 09-20-2012, 05:39 PM
My bad, shoes are 2 1/4 wide, but some more google searching, came up with a few options, most are discontinued locally so I just got the 74 Lincoln Mark IV drums and I will redrill the bolt pattern.
Old 09-20-2012, 06:15 PM
Well there goes that plan, the drums I thought would fit don't. Looks like the diff could be out of a 72 Lincoln Mark IV or a mid 50's Edsel,
Not sure what to do, I need some drums, these thing are so done there done.
9" ford drum brakes THERACER Suspension - Brakes - Steering 5 12-11-2011 01:43 PM
8" Ford diff leaking around pinion nut Curmudgeon29 Transmission - Rearend 5 09-05-2011 08:15 AM
URGENT HELP NEeded d4nz Hotrodders' Lounge 2 04-15-2008 05:54 PM
Ford rear diff ID help needed big boy Transmission - Rearend 6 07-07-2005 11:26 PM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
