I've never used that product but your metal for epoxy should be just good clean metal. Then clean with wax and grease remover, wipe real good with a clean dry lint free rag and shoot with epoxy. The best base you can get. Leave all that other hockus- pockus stuff out of it. If it where me I would clean that stuff off rescuff sand and wash super good with wax and grease and go from there.
SWValcon is giving you good advice. If there is any acid left on the surface the epoxy will not adhere. Clean it well, with wax and grease remover before you paint it. IT MUST BE CLEAN!
John L |
good advice. I'd also go back over it with a da, mini da, hand. Just for a good bite and to make sure all that acid is off of there.
Well, its bit more complicated than that. The axle housing was heavily rusted with quite a bit of pitting on the cast center section. I had it sand blasted but the rough cast still retained a lot of rust in the pits so this is why I used an acid rust dissolver. So the pits of course have acid in them. I've read that acetone will neutralize the the acid. So I will wash her down with that unless someone has another suggestion.
Thanks, Dave |
One of the best washes is plain old water and dawn dish washer soap. Just be sure to rinse good and wipe and blow completely dry.
Soap & water to clean bare metal ????? What do the directions say on how to use this product ?
This is exactly what happens when you rinse acid with water, youve been givin bad advice on how to use acid to remove rust ..first you let it dry 24 hrs and water dosent neautralize it...I dont know about the product your using so I cant advise you on what to do but with the product I use all I would do is a second application with a scuff pad scrubbing out the golden stuff because I believe the golden stuff to be surface rust, something thats sure to happen any time you involve water with cleaning bare metal..read the directions and follow them or pick up some ospho, something thats sure to remove rust and work well with epoxy ...When it drys you just scuff it up real well and clean with W&G remover and prime...I use it all the time with no problems... but getting all the rust gone first is the key otherwise your just encapsulating the rust with epoxy and its sure to bubble up and come back. |
if it has heavy pitting I wouldn't use epoxy, I would use an encapsulator. Epoxy is best with CLEAN metal, and if it's pitted it should be at the point where getting it blasted cleans out the pitting well, if not than I wouldn't JUST epoxy it. Just my two cents, but this is the industry standard of thought on when not to epoxy.
The blaster was not as aggressive as I had asked for. So there were pits with rust in them still. Not a tremendous amount...mostly on the cast center section. I decided to remove the remaining rust with the phosphoric acid treatment (Exorust). The label only states "treated surface will need to be coated" period. Noting about washing or cleaning for prime/paint. So I called Krano back east but it was Friday and they were closed for the weekend. To remove the golden stuff popping up after rinsing with water (rust I'm sure) I just wiped it down quickly with more acid. It literally wiped the rust off. I came across some info that states Acetone will neutralize phosphoric acid so I washed her down with Acetone, let it dry and shot her. Looks great. We'll find out how well the acid worked I suppose.
| Question reguarding painting over old OEM paint + primer sanding | Finaltheorem47 | Body - Exterior | 2 | 10-09-2008 09:16 PM |
| Painting tomorrow, maybe... | kaw550 | Body - Exterior | 3 | 04-12-2008 11:45 AM |
| boat gas tank question (*kind of urgent) | pigjamelectric | Engine | 6 | 09-24-2007 01:07 PM |
| i need urgent help with primers, paint spraying!!!(pics) | prjavelin | Body - Exterior | 13 | 03-31-2007 02:54 PM |
| Urgent paint Help | 70chevy | Body - Exterior | 1 | 03-06-2004 06:26 PM |
