Use of my DA sander - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2010, 08:05 PM
38mike's Avatar
Use of my DA sander
Okay, here's a REAL new guy (new to bodywork, anyway) question. Today I fired up the DA sander to take the surface rust off my stripped metal. I don't know for sure what angle to use the sander at....flat against the surface or with a slight angle to the metal? Angled seems to 'cut' more thoroughly, but......
Also, as I've experimented/played around, I've been having real fits keeping the stick-on sanding pads attached....they like to fly away spinning at 10,000 rpm (Does anyone remember OddJob in Goldfinger?...kinda like his hats did!!).
Advice for a bodyworking newbie, anyone??
Thanks.
Old 06-11-2010, 09:48 PM
Had the same problem with the discs when I first fired up the DA. Solution: Always start the DA flat on the metal or surface.
David
Old 06-13-2010, 03:26 PM
mitmaks's Avatar
Last journal entry: Grille
You never supposed to run D/A at full speed
Half throttle is more than enough. ALWAYS keep it FLAT to the surface of you're just creating low spots/waves
Old 06-14-2010, 08:05 AM
cyclopsblown34's Avatar
Colorsanding painter
Clean the pad on the DA with some alcohol, sounds like the DA backup pad is dirty and won't allow the stickum on the discs to adhere. I've gone to the Hookit II system from 3M and love it. Oh yeah and hold the DA flat to the surface before pulling the trigger on the DA.
best DA sander to get? jss Garage - Tools 16 08-27-2009 06:09 PM
CP870 DA Sander Finaltheorem47 Body - Exterior 8 03-13-2009 05:24 PM
DA sander scratches in rear window rusty428cj Body - Exterior 2 02-15-2005 07:13 AM
Craftsman DA Sander & Sandblaster 70chevy Garage - Tools 10 12-28-2004 09:51 PM
Source of wet-or-dry for DA sander? willys36@aol.com Body - Exterior 3 12-15-2004 06:08 PM
