Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 05-09-2007, 10:11 PM
BillyJoe's Avatar
BillyJoe BillyJoe is offline
Use in tank fuel pump or no?
I have just finished putting a Ford 302 HO in my son's 94 Thunderbird and was wondering if anyone can tell me if there is a fuel regulator available that would reduce the old fuel injection pump pressure down to a useable carb level pressure? If there isn't one, could I just disconnect the old fuel pump and put in a regular electric fuel pump in the fuel line? Would the old pump stop the flow from the gas tank? I really don't want to take out the gas tank if I don't have to.
Old 05-10-2007, 12:54 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
re: Use in tank fuel pump or no?
There was once such a regulator available from MOROSO (PN 65145). Excess fuel volume was returned to the tank via the old EFI return line. It kept the pump cool as does the EFI system.
Old 05-10-2007, 06:46 AM
oldred oldred is offline
I have installed a couple of low pressure fuel pumps and the instructions warned NOT to attempt to pump fuel through the old pump.
Old 05-10-2007, 08:56 AM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
I am using a stock 80 something Ford pump in the tank of the Elky (Bronco Tank)
I think I have an Aeroquip regulator--Been a long timke since I put it on, forgot what brand.
Thee are a couple of the bypass regs that have a alternate spring.
My reg is adjustable from 3-30 and 30-70 I think--not sure, I have it set at 6.
Bryan
Old 05-10-2007, 05:21 PM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
Aeromotive 13301 regulator would work for your needs. it's a bypass regulator, for carb'd applications
Old 05-10-2007, 09:20 PM
BillyJoe's Avatar
Thanks for the responses, I'll check out the regulators. Otherwise, I guess the tank will HAVE to come out.
Old 05-14-2007, 10:07 PM
westfaliaguy westfaliaguy is offline
Fuel Pressure Problem
The stock fuel pump for most Ford fuel injected systems delivers fuel at about 28-32 PSI. This will obviously overcome the float in a carb. A decent quality aftermarket fuel pump will draw the fuel right through the original pump with the electricity turned off, in the tank of a fuel injected car. However the fuel pump will have to work a little bit harder to suck the fuel through this pump to deliver it to the carb in this converted drive train car. The best plan is to take the tank down and fit it with a fuel pickup assembly from an earlier fuel tank or modify the existing fuel pickup to eliminate the electric fuel pump and retain the existing float so that the fuel gauge will read correctly. Good luck with this problem. Yours, westfaliaguy.
Old 05-15-2007, 08:39 AM
BillyJoe's Avatar
Thanks, I was hoping it would be a more simple process but it seems to be the consensus that the tank will have to drop. Oh well, may as well get at it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Use in tank fuel pump or no?"
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
Fuel Pump Not Priming Help!!!!!!!!!! 86camaro2.8l Engine 3 08-21-2006 10:56 AM
Fuel pump question 7dcrzr Engine 2 01-24-2006 10:01 AM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
fuel pump help bowtiebadboy Engine 9 05-23-2005 08:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
