Use Trailer Brake Hose for Clutch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 06:36 AM
Looking at fitting a hydraulic line for the clutch in my 327 Chevy / Studebaker Lark project and I came across flexible brake lines sold for trailers. They are super cheap too. Like 10 bucks for a 24" length. They have the right size fittings on the ends too. Any thoughts or comments on this? Thanks.
Old 07-15-2012, 06:51 AM
LATECH's Avatar
Last journal entry: New Gas Tank
No reason they shouldnt work as far as I can tell. Lucky find.
Fact is stranger than Fiction
Old 07-15-2012, 10:16 AM
Irelands child's Avatar
Why not.
Doesn't need to be DOT certified like flex brake lines, doesn't carry a lot of pressure and sounds reasonably priced.
Old 07-15-2012, 11:20 AM
IS this a plastic line like some of the later GM hydraulic throw out bearings are equipped? If so, I can tell you that when breaking in your engine, having the hose about 2" inches directly above the header will cause the line to melt, and that brake fluid is flammable. Just an FYI.
Old 07-15-2012, 09:33 PM
No it's not plastic. It looks just like the flex hose that is used on the front wheels only less expensive
Need Help With Wiring Trailer Brake Control adantessr Electrical 9 03-30-2012 10:05 PM
trailer brake controller = PWM? curtis73 Electrical 2 02-07-2011 07:17 PM
Which trailer brake controller do you use and do you like it? redsdad Suspension - Brakes - Steering 3 02-02-2009 10:40 AM
04 silverado trailer brake problem shady4 Electrical 2 05-17-2008 08:57 AM
hydraulic clutch hose problems...... bbs383ci Engine 1 06-08-2005 10:34 PM
