used 225 consew sewing machine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2011, 11:59 AM
Bought a used 225 consew sewing machine with table for $200. I want to learn how use it, but before I start I would like to do a maintenance tune-up. Where do I start? Any download manuels, parts manuel or other instructions and recommendations will very appreciated. Its fast what do I need to slow it down? I'm looking for a 206 but for now I'll work with what I got.
Old 11-17-2011, 01:06 PM
DanTwoLakes's Avatar
Wiki Edits: 22
All you need to do is oil it. Your best bet is to take it to a professional industrial sewing machine mechanic and have him go over it, time it, set the tensions, and check for worn parts.
It's intended to sew 3500 stitches a minute, so to slow it down you can put a smaller pulley on the motor or a bigger pulley on the machine or both. Some electric clutch motors can be reconnected to a slower speed. If your motor runs 3600 RPMs, it might be possible to cut that in half electrically.
Here is the manual for your machine: CLICK HERE
I think the only difference between the 225 and 226 is that the 225 does not have reverse, and it has a max stitch size of 3 1/2 to 4 stitches per inch and the 226 max stitch size is 5 stitches per inch. 225 was intended for sewing boat covers or tent canvas, things that don't require reverse and do require larger stitches. For auto upholstery, you'd like to have reverse. It isn't necessary, but it is more convenient.
One last thing, if you got any thread with the machine, throw it away and buy new thread.
Old 11-17-2011, 01:19 PM
Why throw the thread away? How much will someone charge to look and adjust the sewing machine if no parts need replacing? Thanks for the manuel. Where can I get replacement belts the current belts show cracks or should I wait till the belt breaks?
Old 11-17-2011, 01:35 PM
Wiki Edits: 22
Because it would be a shame to sew a car interior and have it fall apart because you used some old bad thread. Especially if there are no labels on the tube to tell you what the thread is. You should use at least size 69 thread, either nylon or polyester, and it should be bonded thread with a left twist. Bonded means it has a lubricant built into it to let it travel through the machine easier. If the label doesn't say bonded on it, but the number is B 69 or B 92 or whatever, the "B" means it's bonded. The belt will probably last forever, but you can buy a belt at any good hardware store for about 6 bucks.
If nothing is wrong with the machine you will pay $75 to $100 to have it gone over. It will be the best money you ever spent.
Old 11-28-2011, 01:50 PM
I own this machine. You can pick a belt up on eBay. I live in NYC and have the luxury of having a real old time sewing machine parts shop over in Manhattan. I took my machine to a local sewing machine mechanic and he charged me 100 bucks to look it over, adjust it and time it - well worth the money.
new (to me) sewing machine mmiller Interior 21 06-08-2011 02:53 PM
consew and sewing leather hot33 Interior 6 11-05-2007 03:28 AM
Got new sewing machine in !!!!!! NEW INTERIORS Interior 1 10-10-2007 05:41 AM
Need help with that sewing machine? KennyG64 Introduce Yourself 2 08-28-2006 09:16 AM
Sewing machine FiLkY tha FELON Interior 9 05-15-2006 01:02 PM
