Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Used 350 SBC $150.
Old 01-24-2013, 06:47 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Originally Posted by WoodmanDan View Post
Thanks for the info. This engine will repower a 1986 C-10. The current engine has piston slap going uphill & smokes 1 qt of oil every 100 miles. Time for an engine swap. I've learned this block is one of the most common castings for the SBC's & is also known for it's desirable high nickel content. I bought the a fore mentioned engine after compression test & listening to it run for 10 minutes.
And you can't beat $150.00!!
