used 700r In 77 shortwide what to do - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-05-2011, 11:40 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
For your question on the other thread about using the crossmember , just move it back and drill some new holes in the frame.
I made a new one from 2''x1'' heavy walled tube because I didn't like the huge stock crossmember.
The front lip was also covering the pan bolts making servicing a pain in the keester.
I would cut the extra material off the front of the crossmember for easy access to the pan bolts.
  #17 (permalink)
Old 06-05-2011, 03:33 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
You'll want to pick up a 4 pin brake switch to cut off the lockup when the brakes are applied if its not included in the kit.
  #18 (permalink)
Old 06-05-2011, 04:15 PM
Yes I think that is it
  #19 (permalink)
Old 06-05-2011, 10:29 PM
SSedan64's Avatar
This is the Model for Electronic Speedo> http://static.summitracing.com/globa.../bmm-70248.pdf
Mechanical Speedo> http://static.summitracing.com/globa.../bmm-70244.pdf
  #20 (permalink)
Old 09-10-2011, 02:41 PM
Vss not working?
Ok its ben a few months but I just got the b m 70248 converter lock up kit , I found out I either needed a electric speedometer ote chang the electric sender to gear driven sender yo work so I just bought a auto meter electric speedometer, well I have it al wired up and the speedometer is not showing any speed it comes on and also the converter never locks up has anyone got any experience with this one?
  #21 (permalink)
Old 09-10-2011, 02:45 PM
Does anyone know a diagram on how wire vsss or maybe how to check if its good
700 r 4 in a 77 shortwide arod777 Transmission - Rearend 12 06-05-2011 10:10 PM
77 shortwide bodywork arod777 Body - Exterior 1 12-15-2010 09:40 PM
judavis75 82 shortwide chevy judavis75 Introduce Yourself 1 04-04-2007 09:40 AM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 01:03 PM
700R Old vs. New rod_one Transmission - Rearend 9 09-07-2003 09:52 AM
