Used but uncapped AC compressor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2012, 03:12 PM
Mutt's37Buick's Avatar
I got a used AC compressor with 130k miles for free, but it was not capped when removed from previous car.
1) Has anyone been successful using AC compressor that was not sealed or capped when it was removed?
2) Is there something I can do now to remove mosture or dirt that may have entered the compressor?
3) Is there a way to test it before actually installing in car system?
Thanks
Old 11-08-2012, 04:27 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
It may be just fine.
What type of compressor is it?
Did you drain any oil out?
Look at the oil that comes out.
To remove moisture, you vacuum the system after it is sealed up.
You can rotate the compressor with your fionger over the port. It should make pressure, that would indicate health.Also you can plug a vacuum gauge into the suction side and turn the compressor , it should pull vacuum.
I usually put a socket on the shaft nut to turn a compressor.
Fact is stranger than Fiction
Old 11-08-2012, 04:38 PM
I did not dump any oil out but I'm not sure ir the person who removed it did.
The 97 honda accord it came out of was very clean as was the rest of the AC system.
Would it be better to put some oil in it and then dump it out to clean any dust or dirt out before turning it?
Just think that would flush debris before it si dragged through.
Old 11-08-2012, 05:06 PM
LATECH's Avatar
You could do that , or you could dump in an approved flush solvent and shake it around, then dump it out.
Flush solvent is pricey, and it is sold in quarts. You could pour in some oil, and dump it out to see what comes out with it. If its clean, your good to go.
When you install the compressor, only dump in 1-2 ounces of oil MAX.
I would only dump in 1 ounce, especially after flushing will oil.
Just be sure to drain the compressor well, then add oil, and after the compressor is mounted and the system is closed ready for evacuation, turn it over by hand 12-15 revolutions, to be sure the oil moves through it and that it doesnt hydrolock before charging the system.
Old 11-09-2012, 03:16 PM
I've installed a lot of used compressors over the years and never had a problem as long as I also installed a new receiver dryer.
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 06:11 AM
help with new compressor cutthroatkid Garage - Tools 7 10-02-2012 09:35 AM
My $25 Compressor!!! Rob Keller Garage - Tools 6 02-03-2009 04:23 PM
compressor cool rockin daddy Garage - Tools 4 09-23-2006 01:50 PM
Compressor Passthru Garage - Tools 9 03-24-2004 09:13 AM
