Used Cam / New Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2012, 01:45 PM
thinwhiteduke's Avatar
Living In The Past
G'day All,
I have a 292H used cam broken in nicely and looks great, done about 300 miles.
Engine is 350 sbc.
I've heards that it's a gamble to put a 'broken in' cam into a different block under any circumstances due to different lifter bore alignments. I ran this past an engine builder here, and he says that breaking in a flat tappet cam is dicey at the best of times, and that if I have one that is already broken into the lifters, then that that is an advantage that outweighs any lifter alignment issues.
I'm confused, I don't wanna buy another cam if I don't have to, but I don't want to take any unnecessary risks. I have broken cams in before ( solid and hyd) without any issues.
Can anyone please give me your opinions on this?
BTW, the lifters have been keep in order.
Thanks in advance!
Old 02-05-2012, 03:10 PM
Originally Posted by thinwhiteduke
G'day All,
Engine is 350 sbc.
Thanks in advance!
If the lifters are in the correct location that they were when it was broke in you will probably be OK. But Murphy's Law is pretty prevalent sometimes. It's a chance that you will have to determine. Good Luck
Old 02-05-2012, 03:20 PM
techinspector1's Avatar
Wiki Edits: 326
Please read this....
http://www.crankshaftcoalition.com/w...ips_and_tricks
Old 02-06-2012, 12:37 AM
Living In The Past
Hey guys, thanks dgcantrellsr and *techinspector for your input. Pretty much what I was reckoning, I'm not much of a gambler when I comes down to mechanics. Murphy's Law will surely come back and bite me. Pity, i have the cam/followers and springs, never mind.....Ok so now I got 2 or 3 sexy doorstops!!*
Alright so I'm gonna get a brand new cam and go through the break in procedure, no prob.**
I really prefer a solid cam *any way so I'm gonna opt for the Comp Cams 294S *or maybe a 280B-8. (or maybe not) there are so many cams out there!! **
I wonder If I can lean on the knowledge of you guys to point me right?
My set-up is:-
350 sbc .030" over with 10.5 to 11.0 :1 *comp ( not determined yet)
Whatever I can get with*KB hypers flat tops (no machining done yet)
Sportsman ll heads 64cc with 202/160 SS Manley *street flows
Victor Jnr with Holley 750 mech
2 speed p/glide. *(sorry). *with 3000stall
Full length headers into 2" twin exhaust system
And 3.55 rear with 25" tyre
In a 3300lb car
I have a set of *1.65:1 *ratio Harland Sharp Roller Rockers that I would like to use, only just because I have them already, but won't use me if it's gonna compromise my set up. If I do use them do I use the AFR #8000 springs?
I know I gotta check geometry etc.*
Or should I just buy some 1.5 rockers?
If so which springs should I use - comp cams has two types listed?
Plus, do I get the 'best' quality lifters available? I only want to do this once!!
I have other engines to work n too.*
I want a 'heavy' street deal *(just like most guys) *with strip meets approx monthly.*
I *know that the powerglide is probably not REALLY in my favor, but that's just the way it is ATM.*
If you could let me know your thoughts, that would be much appreciated.*
Many thanks!!!
Old 02-06-2012, 07:55 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
I blueprint all my lifter bores, so I never have an issue running used cams out of one of my engines to the next..
valvetrain gear can get costly.. I even do it on roller blocks, so the rollers are in the same spot, engine to engine,,
saves you allot of money when you blow up an engine..
Old 02-06-2012, 08:21 AM
Banned
At a high end race level that may make sense but the cost of blueprinting the lifter bores would be more than a new cam, seems a little excessive for a street engine.
Old 02-06-2012, 09:06 PM
Living In The Past
That's interesting stich, that crossed my mind initially, but I didn't realize that it was something that people 'actually' do....
This is a bit of a budget build so I might just give that a shot!, I got the time.
What's the proceedure there? Put the blue on the lobes only then drop the lifters, rotate, then check?? Can't be that complicated, surely.
Can you please give me a brief rundown on how you do it?
Thanks,
Duke
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 06:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 04:37 PM
BLOCK Sanding dyna block or LONGBOARD?? D9ZZ Body - Exterior 6 06-26-2008 08:10 AM
small block big block weight difference Jmark Engine 3 02-04-2008 12:21 PM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
