Used Camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 11:02 AM
Used Camshaft
Anybody have any luck using a camshaft from one engine & putting it in another?
Does Core Shift play a role in how the lifters wear?
I noticed that the lifters aren't always drilled uniformily...
Old 09-01-2008, 11:23 AM
DoubleVision's Avatar
I know of a camshaft that has now been into 5 different engines and it`s still being used. But, I sure wouldn`t have done it, I consider it a miracle it`s worked as many times as it has. Cheap as cams are, there`s no reason not to buy a new one.
Old 09-01-2008, 12:02 PM
The price is so nominal I don't recommend it,
even though it has been done many times.
If it fails, consider the cost of repairing the mess as well as buying a new cam and lifters anyway.
The worst engines I have seen is the lifter bore alignment in the small block Chevy. I have seen some more than .040 out of alignment from the factory= As well as the fact that the cam is not securely retained at the front of the block. The cam floats against the lifters for alignment.
Old 09-01-2008, 12:08 PM
It's not a good idea. If you must, be sure to mark the lifters, so that when you put them into the 2nd engine, they go back on the same lobe of the cam as they came out of. Maybe you'll get lucky......
Old 09-01-2008, 03:56 PM
You can do it, providing you use new lifters. Keeping the same lifters is a mistake A specific lifter bore location from one block has no bearing on the same location on another block. If the cam appears in good shape (or known to have low mileage), get new lifters, use your cam break-in goop and chances are high it will be fine.
For 100% guarantee...buy a new cam and lifters (as the others say above)
installing a roller camshaft chevyelc81 Engine 2 12-16-2012 10:36 AM
Rotella Motor Oil boss350 Engine 14 04-17-2007 11:00 PM
1998 Chevy Venture camshaft kberly54 Engine 2 07-14-2005 08:09 PM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 04:04 PM
BBC Camshaft Specs sb72elcamino350 Engine 6 06-02-2005 05:00 AM
