If it has any gritty stuff in it I would not put in. If the gears are still servicable set them up with correct pinion depth and backlash and it won't make any more noise than a new gear set. If it does the gears really weren't good enough to reuse.
Well the thing is you dont setup a used gearset with .006 backlash... .010-.012 for a used set is fine but make sure the heel & toe contact pattern is correct (if they were setup right to begin with)... Once a gearset has a pattern thats were it needs to be ran if moved to another housing... This applies mainly to street (hard set) gears but the softer "pro" sets are more forgiving in this area mainly because they are not driven on a daily basis...
| 2:41 gears in a 81 Firebird | 81FIREBIRDESPRIT | Transmission - Rearend | 8 | 03-22-2005 07:37 PM |
| Ford 8.8 needs a diff. set of gears...help!! | tm454 | Transmission - Rearend | 1 | 02-27-2005 09:27 AM |
| LT1 Powerband and Diff Gears | 48hillman | Engine | 11 | 09-14-2004 03:42 PM |
| how to change gears.... | jackflash | Transmission - Rearend | 4 | 04-10-2003 03:47 PM |
| Lower gears for caddy diff? | Disordah | Transmission - Rearend | 2 | 12-13-2002 07:18 PM |
