Used pistons? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2008, 04:40 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Used pistons?
Would you ever consider buying used pistons for your motor?
I am doing a 1200 conversion on my sportster and I found some used Wiseco pistons on ebay for cheap... New they are about $300 which seems like a lot for a couple of slugs..
How bad an idea is this?
Old 12-10-2008, 06:22 PM
Wiki Edits: 49
Back in the day people used to replace the rings (re-ring) engines on a regular basis. If you think about it anytime you do a "stock" rebuild and you're installing the original pistons back in the block you are in essence using "used" pistons.
When considering using "pre-owned" pistons one must understand that they need to be cleaned and checked for cracks and damage. If there is none then for a daily driver they are almost always fine. If you're building a performance engine then used slugs probably aren't a good idea.
I'm using a nice set of +.060 pistons in the early hemi that's going in my deuce. Not really building it for performance but it will have a mild cam and 3 deuces. But given the fact that it will see maybe 1000 miles a year I'm not terribly concerned about using a set of pre-owned pistons. Others may disagree though.
Old 12-10-2008, 06:24 PM
You can buy new Wisecos for this money. http://www.wiseco.com/Catalogs/VTwin/EvoSportster.pdf
For less bucks with a cast piston you can look at Hastings http://www.hastingsracingproducts.co...avidson/Detail
Bogie
Old 12-10-2008, 07:09 PM
weirdbeard's Avatar
1976 Ranchero GT
Yeah I think pretty much $200 is as cheap as I could find new pistons.
I am seeing used sets for under $50.
I might just get them and look them over real good.
I hope I don't blow up my bike.
Old 12-10-2008, 07:14 PM
Wiki Edits: 27
pistons
I've mixed pieces whe putting together engines originally made in the 20's. the key is cleaning and carefull inspecting and measuring. I have used the knurler out of my lathe tool box , made a wood block support and pushed hard by hand to knurl aluminum piston skirts then measured and hand sanded them to fit.
Old 12-10-2008, 11:01 PM
OHD's Avatar
OHD OHD is offline
You are doing a HIGH PERFORMANCE upgrade, get NEW pistons to fit the cylinders, after final prep (boring honing etc) has been done.
Hypereutectic pistons and turbos? Hal9000 Engine 18 02-23-2013 08:45 AM
Blower pistons malibu68 Engine 15 12-14-2006 08:49 PM
Cutting down Hyperuetectic pistons??? sizemoremk Engine 10 03-19-2005 08:22 PM
Long skirt SBC pistons fierosum Engine 9 01-16-2004 07:02 AM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 06:39 PM
