useing a holley pro-jection on a blower
I have a 2nd gen holley 900cfm 4 bl pro-jection it has an adjust able ecu "6 dials" the injection system is in a open loop,but I have a holley kit to make it a closed loop system,now for my problem, I have a b&m powercharger minny blower I want to use, the tech guys at holley in the blower dept say it should be no problem running the tbi because is not a blow through system,but the carb/injection guys at holley say I need a map sensor and or a mass air flow sensor so the injectors know to add more fuel on a boost situation and dont lean out,I run 23# of fuel pressure,they say that I must have 3# of pressure for every # of boost,I run 6# so thats 18#pressure and Iam set at 23# 5 over.my delema,does any one know if I can ad a map or mass air sensor to splice into and feed info to my ecu?does any one know anyone running a pro-jection on a blower? thanks for your time...jake
Boost referenced FPR will not do the trick. You would have to run a FMU(fuel management unit) that raises pressure exponentially with boost. They are dangerous in my opinion since fuel pressure can get very high. Plus with disk type injectors they will not work since the injectors will stop firing if pressure is too high.
The best thing to do is look into getting an ECU that can be properly tuned to work with the TBI unit with upgraded injectors and that will run off of speed density(MAP,MAT calcs.) If your ECU can be upgraded you should be fine if it can be tuned for larger injectors. I think you had another post on this where I got the impression you were doing blow through.......maybe my post just did not make it to this one. Oh well. Let me know if you have any more specific questions. I have been dealing with a custom EFI on my truck so it is all fresh on my mind ![]() Chris |
I am not a fuel injection guru, so I would take Chis' advice, he has played with it in a forced induction application., I haven't. I was just kind of thinking out loud.
Royce |
custom efi
thanks for your input.I think my problem after talking with you and a few personal messages is that I have an out dated ecm and I should keep my pro-jection but add a map sensor and a new ecu"controler" which brings up a few dyi controlers ,so far the MEGASQURIT seems to be the best cantadate,but I am still looking.any opinions out there?
Chris |
genboard?controler?
I saw a link someware on this board and it seems to me it was a hard web site to navigate and I didnt see were they sell it.is the genboard a kit also?Iam not much into the guts of a computor,as you can see from the "glassratt journal" Iam into the mechanical side of things,but Iam always up for a challenge.were do I go?and of course how mush?couldnt I just run the megasquirt with a mallory boost timing retard/advance?it would seem functionable and better than what I have now.isnt megasquirt and genboard related somehow?...later jake
www.vems-group.org
I would definately rate the genboard as a more difficult controller to learn because of the greater tunability and more features. If you look at the genboard info pages there is a link to the store. You can buy them from an assembled board only to a complete board in an enclosure, with connectors, and minimal testing to insure operation. The genboard started life as what was called MegasquirtAVR. It soon started evolved into a completely different animal and the firmware and hardware have become something totally different. The only thing inherant from ms is the tuning software which is still compatible, but only can tune about 25% of the variables. It is pretty much worthless and the developers are in the process of building a new software interface. The cool thing is that the genboard is actually tunable with multiple other programs and keyboard/LCD interface. The laptop software is just "prettier" Chris |
thanks for al the background info!
thanks again,I tried to link up I got the web site but got a dns server fault when I tried to go to the store,system must be down?I have till next year to finish this project, but done sooner the better,but I dont want to be in a rush,Iam just checking out my options.this "tow" rig should realy boogie when all is said is done,Iam guessing it is pushing 425 to 525hp and with the blower it should be another 100hp on top,when completed theres a shop close to home that has a chassie dyno Ill keep in touch,the motor is a 350 block with a 3.75 stroker crank"not 400 sbc"internal ballanced with 8,500 rpm red line,4 bolt with girdel,modifyed z28 windage tray,milodon bbc oil pump convertion,9:1/2 to1 forged arais pistons,a large hyd blower cam,cast iron 202 angle pennut plug heads,with about 10lbs of pig iron ground,port and pollished,intake matched to blower manifold exhaust ports hogged to 1"5/8 to match a custom set of block hugger tri-y-headers"lowered truck need ground clearance."1:6:1 roller rockers,stud girdel,and the blower a b&m power charger,got a killer deal on ebay they go for $2,300 and I won the auction and got it for $1,685 its brand new never installed.the truck is a 1976 c10 short box fleetside,nosed ,decked,shaved,and tubed,4:86 gears detroit locker posi in a ford 9" 31 splined axels buildt turbo 350 shift kit,mile marker overdrive splits the gear ratio to 3:88 on the highway.well enough of me honkin my horn ,thanks again...jake
Super Chargers and projection systems.
Industry individual: 46 years of accomplished facets of the automotive technology, I may inform one of the algorithms,(a logical step-by-step procedure for solving a mathematical formula), necessary to accommodate the two systems, creating a well tuned vehicle.
As the TPS indicates, to the ECM, it has moved from the base voltage, idle, the plus rate, timing and additional air supply is modified based on input signals from all sensors. The "If / Then", algorithm, based on the, at warmed and closed loop, formula, is for a normally aspirated engine. If the base e-prom information within the ECM has not been attained, the system changes to an additional Algorithm to accommodate the input signals. The system continues to adapt until it has no additional formulas to continue. At this point, the ECM turns on the MIL light and uses the minimal run function. A Blower and or Turbo compression method, requires, off idle, based upon the load geometry, a larger amount of fuel, lower air to fuel ratio, and retarded timing for a minimal time factor, milliseconds, before beginning the advance curve. Therefore, the two systems may be married, but must be modified technically. Unfortunately, it is not a simple process. Good luck Ignologist |
