Maybe your temp sensor is bad..........
Ontario Rodders |
I think you might want to figure out what "3/4" of the guage represents. It may be a non issue-
K |
Thats pretty much what they are supposed to do....Todays engines are designed to run warmer......My wifes Tempo does the same.
I guess if you wanted to, you could run a switched wire to bypass the sensor............
Ontario Rodders |
lowering the voltage ( adding resistance ) will cause the temp sensor to read low. the closer they get to full refrence voltage ( 5,8, 10 or sometimes 12v ) the hotter they read.
Doc here,
The sensor for the fan is not a resistance based device..It is a bimetallic SWITCH..adding resistance to it will change nothing (except possible burnout of the resistor) To lower the value of the turn on time, you must select a Sensor SWITCH that has the temp values you are seeking. (160 degrees, 180 degrees , 195 degrees and so on..) Probably an aftermarket type will be needed. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
I have a 91 taurus station wagon with a 3.8, ( It was free, passes smog, and it has air conditioning that works. so?)
The temp stays in the 3/4 range all the time. Never had a problem because of it. If you can get in the paper buyers guides at your parts stores, you may be able to find a sensor with the same fitment, but a lower temp. I have a Four Seasons catalog that shows a picture, an application and gives a on/off temp. Cross referenceing to a lower value is time consuming, unless you can find an aftermarket supplier with one already sorted out. Some of the wiring companies as well as jegs and summit sell them. Whether or not they'll fit that taurus is another matter. Try Ford Motorsport. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 02-13-2007 at 04:58 PM. |
You need to find out if you are actually having a overheating problem?? There is a lot of engineering that goes into the design and operation of modern pcm/ecm controlled engines. If you start trying to " cheat" the system you could end up with bad fuel mileage, decreased performance, increased emissions (if you live in a state where they check that). In some cases it might shorten the life of the engine. I know on my wifes 93 lumina 3.1L the fans didn't come on till like 210* if I remember correctly. That's why cooling system maintenance on modern/newer vehicles is critical. There is a fine line between normal and problem. I also know that in the early 80's Toyota changed the head gasket style on the 22R engine. It had restrictions for the water passages, this was done to increase cyl head temp to lower emissions. But the flip side to that coin was the aluminum head, if you had a small problem with overheating you could be reworking the cylinder head or worse yet complete overhaul from scored cylinder walls. I've seen it happen several times. If you can get your hands on something like a raytek heat sensing gun and check the temp at a few places in the cooling system you should be able to tell if it's overheating. The service manual should give a fan on temp spec. Good luck with what ever you decide to do just be careful Hot antifreeze burns
I think most of the Fords have a dual speed fan that compensates for increasing temperature conditions.
If stage one is insufficient and the temp continues to rise, stage two kicks in. |
| Electric Fan Temp. Sensors | horvath | Electrical | 26 | 04-26-2011 03:04 PM |
| 95 Camaro fan switch problem / ignition key problem | human_forklift | Electrical | 7 | 10-24-2004 11:37 AM |
| electric fan or clutch fan?? | mancinator | Engine | 4 | 06-02-2004 02:49 PM |
| Electric Fan | screamin340 | Engine | 3 | 05-22-2004 03:12 PM |
| EZ-Wire : Fan Connection | horvath | Electrical | 11 | 03-28-2003 10:35 AM |
