User name change - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 01-20-2008, 11:27 AM
10secden
User name change
I would like to change my user name so that my real name is not used.
I would like to use.. 10secden as my user I.D.
Old 01-20-2008, 11:38 AM
63CustomCab's Avatar
Like two monkeys...
Last journal entry: 383 Engine Build
Go to user Cp and then chose the edit profile link on the left side about 1/3 down the page, you can in put it there
Old 01-20-2008, 11:40 AM
Like two monkeys...
Spoke too soon, it's not there. Not really sure...but I'm new here too.
Old 01-20-2008, 11:43 AM
Like two monkeys...
Go to 11/19/06 thread User Id, there is a post by Jon at the bottom, the administrator, send him a private message and he can help with the user name, as for the password, you can do that under the user cp tab at the top left bellow the HotRodders logo.
Old 01-21-2008, 02:37 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
If Jon does not see this and change it for you (busy guy), just send him a message and he will. Not a problem at all.
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
Can I change from a 28 to 26 spline carrier? artillerystevens Transmission - Rearend 0 03-05-2007 11:53 AM
Small base circle cams / pushrod length change??? hotrodf1 Engine 1 12-05-2006 10:49 AM
User ID Northstar John Hotrodders Site Suggestions and Help 3 11-19-2006 09:39 PM
user name change dave mork Hotrodders Site Suggestions and Help 0 09-07-2006 11:40 PM
