Using 18 degree pistons in a 23 degree block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2008, 07:23 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have a set of dish pistons that are supposedly for a 18 degree block but can these be used in a 23 degree block? What is the difference other than 5 degrees? There is no valve reliefs and the dish is round.
Old 03-10-2008, 07:52 PM
It is not the block that is 23 degrees it is the head/valve to piston angle. You will have a problem if you need a valve relief because it will be in the wrong spot. But if you do not need the relief you should be OK.
Old 03-11-2008, 03:52 AM
S10 Racer's Avatar
Thanks Mike H. BTW, I see you are from Kemah. Been there and done the boardwalk. Nice area.
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 02:01 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
need advice on sbc pistons 23 to 18 degree jsteve068 Engine 1 10-10-2005 05:55 AM
18 degree vrs. 23 degree BERN Engine 1 01-17-2003 06:21 PM
