Using 1937 Buick instruments in restomod - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 09:07 AM
Mutt's37Buick's Avatar
The electrical system and drivetrain will be from a '95 Buick.
My original plan was to use the '95 intruments as well, but it is really too wide.
1) Can anyone tell me if '37 Buick original instument cluster can be adapted for use on a modern 12 volt electical system and speedometer hooked up to a 4L60E transmission?
2) If the original instruments cannot be adapted, can someone recommend a donor car, or aftermarket instrument, with a similar rectangular confuguration?
Thanks
Mutt
Name:	Orig Franklin steering wheel.JPG
Old 06-18-2012, 10:32 AM
EOD Guy's Avatar
Might think about retro-fitting new gauges in the old housing bezel
http://www.dakotadigital.com/index.c...rod/prd725.htm
I used the VHX gauges in my Camaro and love 'em
Old 06-18-2012, 04:58 PM
refurbish old gauges
There are companies out there that will rebuild and convert your old gauges to a 12 volt system. When they are done , they look like they just came from the factory. Pick up a copy of Hemmings Motor News magazine and brouse thru the mag. If I can find the listings, I will post the contact information later.
Old 06-18-2012, 05:03 PM
web sites
Here are some companies that repair gauges.
justdashes.com gaugeguys.com dandmrestoration.com ClocksAndGauges.com
Is welding frame of 1937 Buick OK? Mutt's37Buick Suspension - Brakes - Steering 3 04-26-2012 01:22 PM
455 in 1937 Buick Mutt's37Buick Engine 3 05-13-2011 03:35 PM
1937 Buick suspension upgrade Mutt's37Buick Suspension - Brakes - Steering 6 03-18-2011 08:56 AM
1937 Buick lowered Obmlr Suspension - Brakes - Steering 6 11-26-2009 10:14 AM
1937 Buick front Spindle Interchageability SteveHotRod Suspension - Brakes - Steering 4 01-16-2008 10:05 AM
