Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using the 2.3L ford in a rod
Old 01-10-2013, 06:30 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: New Gas Tank
Good choice. The 2.3 is a good engine .
Over they years of its use it went from a pinto motor to a ranger engine. The early ones were carbed, the later ones EFI. you can convert a newer EFI back to carb if desired. There is also a dual plugged version that you can use. Parts from all years seem to interchange. I have used carb intakes on EFI motors.
I would do some reading on the dual plug version to be sure how much stuff actually interchanges. I used an early EFI engine (single plug version) in an older ranger and had to do some parts swapping, but with both engines at my disposal I had everything I needed. It ran pretty good.
IIRC the dual plug version had roller cam setup in it.
A turbo ed one from an 88 super coupe would be sweet.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
Ironpony (01-10-2013)
