You can also turbo the 2.3 ranger motor as long as its the right year. But will have to pull the boost back. Be sure not to use the newer block with low tension piston rings. They will have masive blow by under boost.
Also be aware the engine is tall and not as narrow as it would seem. They will take up about the same amount of room as the v8.
