Using a bead roller...backwards... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 05:33 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
I think this would be the correct forum for my question. I have a bead roller, but the piece I need to roll is longer than the throat. Does anyone have any
suggestions. Can I feed the piece from the outside versus the inside, if so, any tips.
Thanks,
AngliaBob
Old 02-18-2005, 11:30 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
This is trying to roll a bead on the edge of a really wide piece of metal..?? the only issue I see is how to support the metal while rolling the bead..Normally the metal is supported in the throat of the roller..so maybe some kind of table to support the metal and someone to help guide it through the roller..??..
OMT
Old 02-20-2005, 08:19 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I mounted mine on a table for this reason. You can invert the die's for doing curved pieces.If your like me,help is generally scarce when you need it.
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 01:18 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Solid Roller Setup/Best roller lifters? fearsomefairmont Engine 1 06-26-2004 06:41 PM
Roller or flat? When is a roller needed? killerformula Engine 3 11-10-2003 03:58 PM
Roller cams MI2600 Engine 4 11-28-2002 06:40 PM
