Using a bead roller backwards??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 06:21 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Hello all...
I have a piece of work , that will not fit in the throat of my bead roller. Can I feed the work in from the outside edge? Any tips or suggestions would be appreciated.
Thanks,
AngliaBob
Using a bead roller...backwards... AngliaBob Body - Exterior 2 02-20-2005 08:19 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Solid Roller Setup/Best roller lifters? fearsomefairmont Engine 1 06-26-2004 06:41 PM
Roller or flat? When is a roller needed? killerformula Engine 3 11-10-2003 03:58 PM
Roller cams MI2600 Engine 4 11-28-2002 06:40 PM
