Bondo is great stuff....................however, the less you use the better. If it's too thick it will fall out, crack etc.
Rust will still form underneath it, so make sure any repairs are done properly, before applying the bondo. It should only be used for minor imperfections, not filling big dents.
Ontario Rodders |
Bigger holes.....you need to weld in patches or repair panels.
Bondo will not repair them, it will fall out.
Ontario Rodders |
Look at "bondo" as a "smoothing" tool, NOT a "repairing" tool.
If you were really after a cheapie job you could use a fiberglass reinforced "bondo" and if you clean up the rust good before it will do amazing things. HOWEVER, this is miles from the right way to do it. By the way "Bondo" is a brand name, like Cresent wrench or Kleenex. It is a common slang term for "Plastic filler" or "Polyester body filler". "Bondo" brand is most found in the "McAuto" stores like Kragen or Pep Boys. It is not a bad product, but usually "retail" packed and VERY expenisve. Evercoat is probably the most popular brand and is very respected in the auto body industry. |
| Which bondo should I use? | Nightfire | Body - Exterior | 8 | 07-26-2004 05:38 PM |
| Bondo vs Dynatron | ChrisMiddleron | Body - Exterior | 10 | 08-29-2003 04:07 AM |
| How long does it take thin amounts of bondo to crack? | stonedchihuahua | Body - Exterior | 14 | 07-12-2003 08:02 PM |
| bondo removal question | broncoman | Body - Exterior | 3 | 06-22-2003 01:16 AM |
| Help with bondo / bodywork please =) | manofsteel | Hotrodders' Lounge | 3 | 12-04-2002 07:05 AM |
