Using copper pipe for heater lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2004, 06:12 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Is there any problem using 1/2 schedule L copper pipe as heater lines? I wanted to route my heater lines along the firewall and I need to make some 90 degree bends out of the heater core. Is there any problem using copper with anti freeze? Pressure shouldn't be a problem, I'm worried about the copper interacting with the brass.
Also I need a manual heater valve, anyone have a source for them?
Regards
Mark
Old 02-09-2004, 06:21 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Copper alloys, bronzes and brasses are generally very compatible being copper based metals - that solder joint is common in residential plumbing. Copper and brass is used together in conventional radiators. Problems come in when you mix widely differing metals copper/iron, copper/aluminum, iron/aluminum, etc.
