Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using Fisheye Eliminator
Old 10-04-2012, 12:19 PM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
If doing a base coat/clear coat paint job, you can dust the base over the affected areas rather dry for two coats and then proceed to apply the successive coats as you would normally.
