Using a Flow Coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2005, 10:14 AM
Using a Flow Coat
Hi,
I'm about to squirt what for me is a high dollar car (66 vette) for a customer.
Normally I just shoot 3 coats of our high solids clear and cut and buff that.
It works excellent and I very seldom get much peel. But I do
get some puddlies (urethane peel) usually on the top surfaces. Of course I'll try to control that by not piling it on.
Anyway, I see quite a few are now using a flow coat for a better finish. So I have a couple questions for those who do this.
- Is it worth the extra time, effort, and risk of contamination?
- Do you just squirt one flow coat?
- What happens with your final cut and buff? If you sand through that flow coat is it noticable?
- This car will be silver (OEM color). Will it be worth the effort considering that color kind of hides the surface defects moreso than a dark color would?
Thanks!
Larry
www.autopaintdirect.com
Old 12-29-2005, 05:48 PM
Last chance for any input. I'm shooting the sucker hopefully tomorrow night.
Larry
Old 12-29-2005, 06:17 PM
Custom builder and painter
Last journal entry: Another test fit of the axle
well no one seems to have any answers.. what clear are you using... I just sprayed some Spi universal clear and it looks unbelievably flat, I don't think it'd need the flow coat..lol... Here's what i'd suggest... spray 3 coats of your HS clear... and then make a call if you look at it and say it looks excellent.. just wet sand and buff it as you normally would.. if you'd like to get a better finish, wet sand it it with 400 and re-clear with a MS clear of some sort.. but from what I understand you'd want to put 2 coats of clear on so that way you can wet sand and buff, and still have enough mill build for longevity..
If you are planning on doing it with the same clear.. just reduce it like 5% when you do the final coats.
Old 12-29-2005, 06:55 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Main thing on a high dollar job is to be patient and observe the flash times and do not try and run the material on too quickly and get a pile up..Saying that I would rather have to deal with a run than deal with orange peel..
If you have been getting a good result and are comfortable with the material you are presently using go for it..
With some materials a bit of reducer helps it to flow out a bit better but in no case would I go over 5% with the reducer..
OMT
Old 12-29-2005, 07:24 PM
BarryK's Avatar
Larry,
Not real up on exactly what a flow coat as far as ratio is but sometimes in the last coat too a quart of mixed clear I will add 2-4oz of 885 or 895.
Mostly do it to keep last coat open a little longer if I'm really loading the clear on. Not sure it does much good but it sounds good.
Make that vette look good!
Barry
Old 12-29-2005, 07:25 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
As asked, WHAT product are you shooting?
Different clears need different reduction.
A flow coat IS and over reduced clear or lesser solid clear made to FLOW out.
10% is the normal reduction for "most" clears.
UC-35 HOk is their basic clear and does a great job but if your flow coating you will 5-600 wet sand and use the UFC-35 which is a flow clear designed especally for this.
The SPI universial is also reduced 10% for each flow coat,not just the last according to Jim (mrcleaner6) who did this on the yellow Firebird awhile back.
One of the main reasons for flow coats is to smooth or flatten out the main clear job with sanding and add a luster coat which adds extra depth and shine to the job.
The advantage to flow coats is that your shooting over a clear (same) base instead of a paint which means you can hammer the flow clear pretty good as it sticks to itself a lot better than paint so the likelyhood of run's is less than the first go around.
It's also a chance to fix any last mistakes missed.
FWIW, Mike.
Old 12-29-2005, 07:44 PM
It's worth the extra work IMO. Apply your normal three coats then block the car with 400 or 600 depending on how much urethane peel needs to be removed. Then apply one or two flow coats. When colorsanding and buffing if you sand or buff through the last stage of clear and into the first you won't see any differences, no rings, etc.
The flow coat allows you a chance to put a nice smooth coat of clear over a perfectly smooth and flat surface that has already purged most of the solvents out. The more coats that are applied in one session make for more chance of texture stack up, urethane peel/waves.
Silver doesn't hide surface imperfections more than a dark color, In fact silver highlights surface texture problems, scratches, peel, etc. The reflection silver provides will show much more surface irregularities than any dark color. Silver needs a completely smooth, flat, straight and scratch free surface.
Old 12-29-2005, 07:53 PM
wow that amazes me that if you sand thru you won't see any ring, or have any peeling problems.. it's still a thing layer over the top and if you sand thru you are slowly tappering it down to nothing.. and it seems like the edge where your going thru would be 400 grit and that would be hard to buff.. hmm.. learn something everyday.
Old 12-29-2005, 10:21 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I think when the clear is only a day or two old the next coat just bites in and pretty much melts any sanding marks and becomes one with the substrate. I've seen jobs done that way, they look awesome and give peace of mind as to mil build and UV blocking.
Old 12-30-2005, 08:09 AM
Bee4Me's Avatar
You will rarely cut thru a flow coat as it's generally VERY smooth and o'peel is almost nonexistent.Usually a light 1500 or 2000 then a 3 or 4K "pad" then buff. This is another one of the reasons to use them.
Some painters will even shoot straight reducer for the "last" coat on the top flat panels to flow it out smoother.I'm not recommending it but some do. I've done it on some small projects that are not kept outdoors and it does flow it out smooth and requires no buffing IF you don't have any trash in it. For a real world car,I'd just keep it at the first shooting if it looks good.
Old 01-01-2006, 08:30 AM
Thanks for the responses!
I still haven't shot the car as I keep finding tiny things to fix.
I want it perfect so it's taking a ton of extra time. I normally do
three blockings on a car and then shoot. We did six on this one so
I'm really tired of sanding. But if it comes out better than the rest
in town it will probably lead to alot of work down the road.
So today is paint day!
I'm using Valspar AC4400, it mixes 2:1:1. I suspect but can't get verification that it's the same as HOK UC35. We are a jobber for both. Urethane peel is something I have always had a problem with no matter what brand of clear I've used. I'm pretty sure I just put it on too heavy. So I'll watch that as I spray. We don't do alot of volume as selling paint is most of the business, but I normally spray a couple times a week. This one is not my first kinda high dollar car or Vette but the others were my cars, not a customers. For some reason this one has me unusually concerned about perfection.
Larry
Old 01-01-2006, 09:08 AM
Use the slowest reducer you can get asway with and let each coat tack up. Get your gun adjusted so you can apply the smoothest thinnest coat possible. If everything goes right you might not want or need the flow coat. The worst urethane peel seems to be a product of too fast a reducer with the required bombing the product on thick to get it to appear smooth and poor gun atomization. JMO I've never used Valspar, maybe someone with product experience on this one will chime in and give a few pointers. Bob
Old 01-01-2006, 04:36 PM
Well, it's painted. I don't see much peel but I think I might do the flow coat anyway. There's one spot that I don't like so I could rebase that lightly beforehand. I guess it depends on how abmitious I am in the AM.
Thanks for the help!
Larry
Old 01-02-2006, 10:28 AM
crashtech's Avatar
Technician
Wiki Edits: 17
Hey, if you rebase anything you'll need at least 2 coats of clear over that to achieve UV protection, but you probably know that...
Old 01-02-2006, 10:36 PM
Looks like it will work pretty slick. Sand and buff tomorrow.
BaddBob,
I'm in Escanaba, only an hour or so from you. If you drive like I do.
Larry
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
body line cole5_0 Body - Exterior 13 10-14-2005 03:57 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
laminating- gel coat pre-release powderbill Body - Exterior 5 06-12-2005 05:59 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
