Using a Grinder to remove paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2006, 02:06 PM
This is a little technique for removing paint with a grinder/sander.
Get a 7" backing disk and 8" sanding disks in both 36 grit 80 grit and 120 grit.
To remove paint and not metal, move the sander up/down.
To remove metal move left/right.
Start with 36 grit to quickly remove the paint going up and down. Then switch to the 80 grit to remove the 36 grit scratches and finish up with 120 for a mirror like finish. Then prime and paint.
If you can find the 120 grit in a flap wheel, those are the best.
Old 07-27-2006, 04:56 PM
scrot's Avatar
Please explain how the up and down works differently than the left and right.
Old 07-28-2006, 01:07 AM
it all has to do with the was the sander/grinder makes the cross hatch pattern. Up and down doesn't bite into the metal as hard there for it will only remove small amounts of metal were as left and right works more with the directional pull of the grinder. Try it out on a old fender and you'll see what I'm talking about.
Old 07-28-2006, 01:22 AM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
I still prefer aircraft stripper, and then a little wirewheeling with a fine wire cup. Doesnt remove metal.
Old 07-28-2006, 03:16 AM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Plastic for me...
I get those double-wide 3M stripper wheels, and chuck them into my old Chicago Pneumatic inline die grinder. They take paint, bondo, and rust off down to clean metal, and leave a tooth like 180 does on the steel. Very little actual metal removal.
Even at 8 bucks a wheel I got the Kustomsledd completely down to bare metal in a weekend, using up 6 wheels in the process. That's under $50 to strip the whole thing
Old 07-28-2006, 08:39 PM
grinding paint
angle die grinder
2" flat "scotchbrite" discs + arbor
medium removes grind marks
coarse puts grind marks in
strips paint/rust quickly- mirror finish and very quick
Old 07-29-2006, 07:51 AM
Wiki Edits: 31
I get out my DA sander with some 80 grit ( don't buy the HF stuff, it's not true 80 grit and it wears out quickley ) and it works good. I use the 3M rolloc discs for grinding out welds and heavy bondo where it shoulden't be. the thing you need to remember about grinding wheels is that, they make a lot of heat, so much heat that it can cause panal warp, even if it dosn't grind away at the metal.
Old 07-29-2006, 08:30 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
i prefer 36 grit on an airboard
its slower, but at the same time theres more sandpaper-to-paint contact, so it evens out in the end
and since your using less speed, and theres time between passes ovr a section, theres less heat transfered to the panel, way lest kisk of warpaqe for thin panels
ive said it before.... ive stripped aluminium hoods w/ airboards b4 ... none ever warped .... a grinder would have DESTROYED them no matter how hard i tried to be carefull ....
Old 07-29-2006, 10:33 AM
Wiki Edits: 27
removing paint
I use the method furniture refinishers use. first i use a good putty knife sharpened to razor edge. adjust the angle to the saurface and scrape. no grind marks and the scrapes are wide enough to remove it faster with NO DUST . for edges i use aircraft stripper, more scraping and then my 25 horse power washer I use for cleaning my heavy equipment, tractors, etc minimal sanding with 80then 120 paper and its ready for primer
Old 07-29-2006, 11:29 AM
I would NEVER recommend (even if I could do it) to any newbes to touch a car body with a grinder to remove paint.
Using an orbital sander like a DA or "Bondo hog" is one thing, but a GRINDER, sorry, NO WAY.
Old 07-29-2006, 04:01 PM
i agree with brian. I use my orbital sander (mud hog, as brian said to remove paint) National Detroit makes a good one, but I got a snap on one that is a bit underpowered, but does the job with a little more time involved. Less chance your are going to heat up or remove to much metal with an orbital. Most guys will say start with 80 grit to remove paint, but I use 36 to get the bulk of it off. Even back working in a dealership and being new to the trade, when we had to strip many paint pealers in the 90's I haven't had a problem starting with 36 grit to get most of the paint off, then switching to a 6" da with 80 grit to finish the job off. A grinder scares me for most guys to use, it really wouldn't take to much to go to far and remove a bunch of metal, or heat it up enough to warp it. And if you have any aluminum parts be careful how you deal with it, aluminum will heat up fast.
Old 07-29-2006, 06:41 PM
Actually I know of a guy who used a variable speed grinder(polisher?) with 36-60 grit discs to remove paint. My first thought was the same as what you guys are saying but after watching him run that thing at a fairly slow speed it seems to remove paint quite fast without much damage to the metal. IMO there are better ways of doing this and I don't think I would want to strip a car this way but it seems that as long as the disc is used at relatively slow speeds it can be made to work fairly safely. The key here would seem to be the slow speed however I still think there are better methods of paint removal because no matter which way you move that thing there is going to be some metal lost with a 36 grit disc.
Old 07-29-2006, 07:13 PM
BarryK's Avatar
Great advice:
Although I have stripped 100's of cars with a 4" and 7" 24 grit grinder over the years a first timer is asking for problems. In the 70's if a panel needed stripping at the dealership that was the only way we had of doing the job.
Bondo hog although I have never used one would be your tool of choice and from what I hear just as fast.
Old 07-29-2006, 07:21 PM
SuthnCustoms's Avatar
Crazy Ole Ironhead
a DA,mudhog or paint stripper is about the only safe ways to do it safely & efficeintly...although i have used a wire wheel on a 4 1/2 inch grinder & had good results but was VERY carefull not to stay in one area long..those things run at 10,000 RPM's..causing alot of fast friction heat to the panel & also if used on the metal very long you are going to have to sand it afterwards anyhow because it polishes it & leaves a film & very easily warp the panel from the heat
im with Martinsr on the NOT using a grinder..hard for even a seasoned pro to do it without damage
and ive seen guys use the samething as Oldred mentioned but like he said..VERY slow speed
ive never seen it matter which way you use the sander..left to right or up & down.................
Old 07-29-2006, 07:33 PM
BarryK's Avatar
ive never seen it matter which way you use the sander..left to right or up & down.................[/QUOTE]
The old guy that taught me to use a grinder wanted done that way mostly to keep the metal cooler but if nothing else he just wanted that grinder moving and not being held still, I agree with you and don't think it would matter with a mud hog.
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 09:31 PM
Dupont Paint joeford Body - Exterior 16 11-18-2005 03:17 PM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
