Using Jacobs nitrous mastermind with a MSD Pro-Billet HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 06:54 PM
iambigperm's Avatar
Top notch hack
Reading the directions on the Jacobs NMM it says that it must be used with an aftermarket ignition box like a 6AL. By looking at the given wiring diagrams it looks like I could wire the NMM between the distributor pickup and the ignition module in the distibutor. Anybody think this would be a problem? My Pro-Billet HEI works perfect and I don't want to add any unneeded stuff to the picture(6AL Box).
Old 09-05-2010, 03:09 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
That appears to be correct.
The NMM controls the spark timing and features an adjustable rev limiter.
Did you see this? ---- www.jacobselectronics.com/pdf/NMM_PT1.pdf
Old 09-05-2010, 03:12 PM
ericnova72's Avatar
More for Less Racer
Linky no Worky
Old 09-05-2010, 03:17 PM
vicrod's Avatar
life is a ride
Link is now working.
vicrod
Old 09-05-2010, 03:57 PM
LATECH's Avatar
Last journal entry: New Gas Tank
would there be a problem with the pickup not generating enough signal to run both. Seems to me I saw something about that in the msd site.I think they recommended a tach adapter (probably an amplifier) to do just that. Just asking..dont know myself.
Old 09-05-2010, 05:44 PM
vicrod's Avatar
life is a ride
I have never installed one of these controllers but the detailed instruction book implies that the NMM is compatible with all types, although it doesn't mention this one (6al) specifically, of electronic and point type ignition systems including non distributor ECU systems.
The NMM takes the pulse data and regiggers it to retard timing and limit revs and who knows what else.
The 6al provides the high voltage juice for spark. Also it has a rev limiter. I would set the 6al rev limit a little higher that NMM.
vicrod
Old 09-06-2010, 10:30 AM
iambigperm's Avatar
Top notch hack
My Pro-billet HEI has a rev limiter built in to the module. What I'm wanting to know is if I can use the NMM WITHOUT an ignition box like a 6AL. Looking at their diagrams it looks like if the NMM was wired between the pickup inside the distributor and the MSD HEI module(also inside the distributor) it would work fine. Does that sound like it would work?
Old 10-31-2010, 03:31 PM
MSD 8365 hei
If your just looking to retard timing for nitrous The MSD 5462 retard will be much simpler and much cheaper here's the link for the wiring: http://www.msdignition.com/assets/0/...dd418971fe.jpg
I have the 8365 distributor myself and am planning on hooking up the nitrous system as soon as my controller arrives.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
Pro Billet Distributor Blazin72 Electrical 2 06-01-2006 09:35 PM
MSD Pro Billet timing question singletoncamaro69 Engine 3 10-28-2005 10:40 PM
msd pro billet stuartc Electrical 1 09-06-2005 01:27 PM
upgrade hei or go all msd Super Chevy Electrical 9 01-30-2004 12:59 PM
