using a jamb nut for rocker adjustment nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2004, 01:25 PM
Muscle car fan
To prevent my rocker adjusting nuts from backing off, can i use a jamb nut that will stop the other from backing off? What grade of nut would i need? i'm guessing grade 8?
Thanks for the help
'74 Gran Torino Project
351W, c6 trans, 9"
Old 07-19-2004, 01:44 PM
DoubleVision's Avatar
I just go to the junk yard and find a "virgin" engine, or one that`s never been stripped down, I snatch the rocker nuts off them and in every case so far it solved the problem.
Old 07-19-2004, 02:16 PM
MI2600's Avatar
Member# 3287
My son used jam nuts on his Ford rockers as an emergency measure. As far as I know they're still there w/o a problem.
I would think grade 5 nuts would be adequate. Grade 8 is probably an overkill, but if you'd feel safer, do it.
Old 07-19-2004, 03:25 PM
King of my Man-cave.
If you need to use a hard nut, use a connecting rod stud nut. Actually, any grade 5 or better nut will work fine. I'm using the same system on my 350 right now. Works fine and is cheap!
tom
Old 07-19-2004, 03:31 PM
Muscle car fan
tom
wonderful, saved myself $30
351W, c6 trans, 9"
