Are you gonna ask this question till you get the answers you want?
look at this link. http://www.airfuelmeter.com/english/ with a carb, vac. advance, etc, there just isn't that much to monitor. If you can't check your air/fuel mixture with conventional methods, then by all means buy a wideband O2 sensor and some ridiculous software to monitor it for you. BTW, is a labtop computer one you have strapped to your dog? |
Moderator sez "never mind the peanut gallery" Try one of these as this monitors mixture in real time..:
http://www.rbracing-rsr.com/rsrgauge.htm Get the dual output and place a probe on each bank so you can tell if one bank or the other is lean or rich..one probe can give a good indication though.. here is another item which may be of use to you: http://performancetrends.com/road_race_DataMite.htm this is a data logger that tells you how the car is performing on the track..might be a bit of overkill for a street guy.. Couple of more ideas for you.. Sam
With just a carburetor and no computer using a laptop would be just a high tech way of approaching a low tech job. I guess there would be software available but again without an ECM it would do nothing more than allow you to check various parameters which could be done easier, and a heck of a lot more cheaply, using conventional test equipment. By the time you buy software, cables, etc, will have spent enough to have bought a good DVOM, timing light, etc that could be used for other purposes but of course they would not have the "wow" factor.
A wideband O2 sensor, a vacuum gauge, DVOM and a good timing light should be about all you need to precisely tune that carburetor setup.
| Recent Garage - Tools posts with photos |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| Knowledge base | Dave57210 | Hotrodders Site Suggestions and Help | 2 | 12-20-2009 07:06 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Engine tune up specs 350 sbc | Bluepen | Engine | 4 | 03-14-2006 01:33 PM |
| Tune Up. Check Engine Light | way_2fast_4u | General Rodding Tech | 3 | 04-26-2003 09:19 PM |
